Exodus 4x4
Imagine what it would be like to have both the EVO Lever, and double triangulation.
GenRight rear setup has 8 joints. Evo Lever has over 20 by my count. Now tell me which one has a greater chance of something happening?I would... but thatās just me.
Maybe someone can give me an exact figure but by my count the Evo DTD front, lever rear, high clearance long arms, skid plates and misc parts is around $12k. GenRight kit can be had right now for $13.5k....That said for the money your awfully close to building a buggy with a jeep body on it. I mean seriously I think you could sell your jeep, buy an aluminum tub and build it up for less. Hmmm.
IrishJK I am not happy with the control arms locations as they hang up on large obstacles and I need more articulation. I could easily swap out my front bolt on setup for the DTD but the lower control arm mounts would still be in the same location. Where as the GenRight kit all control arm locations front and rear and tucked up both at the axle mount and the frame mount. By using their cross members and eliminating the factory fuel tank I will gain approximately 3" of belly clearance allowing me to clear larger obstacles that would otherwise be an issue with my wheelbase. Again out back all control arm mounts are tucked up. In addition a double triangulated rear has no rear steer. In addition to hitting my rear control arms mounts I hit my bolt on coil over mounts since they hang below the axle. All these issues are addresses using the GenRight kit and I will gain 4" more travel in the rear.
I believe it was his lower rear... unbolted it and drove out.
Passenger rear upper is what broke and it was after literally hundreds of thousands of miles. Iād say the EVO kit is squared away and proven itself over and over again.
You did feel inclined to mention a āwhat if something breaksā scenario in your list of reasons why you would go with Genright. Just saying...
Gee thanks but that won't fix the short comings in Evo's designBacking up and trying a different line..... Priceless......
Same can be said for breaking a lot of other things.Not to mention if you break an arm on a 3 link kit, youāre likely done for the day and headed home on a hauler unless you can make some kind of trail repair. Iāll take the occasional bind and some of the so called downsides to a 4 link for the added insurance.
Right... my bad.
There is another option coming out that will be less expensive and in my opinion a better kit than GenRights. Donāt get me wrong, I like GenRight products and Iām happy to sell them when someone asks, but the cost of that kit plus the install is crazy. They actually recommend you buy another frame to build it on and then swap the body over.
Check out Motobilts kit on Instagram and follow the progress. It should be available early next year.
Personally I love my EVO lever but I might be changing it out for a couple of reasons and none of those reason have to do with performance of the suspension itself. I will not be changing the front DTD and actually run it as a 3 link now.
