Hello all there
I just installed ARB CKMA12 compressor in my 2012 JKU using the EVO bracket. So far only the mechanical part is installed.. (Compressor mounted to bracket and bracket mounted under the hood)... So far all looks good
Next step would be to connect all wires and harness and actually make it work. I bought the complete kit from Northridge4x4.com...
I will be using this compressor STRICTLY for airing-up my tires, so I want my switch under the hood next to compressor. I will not be using it for lockers..
Now my question is, do I still need to use the “pressure sensor” and the “three way splitter” or can I just attach the “ARB air compressor valve” directly to side port on the tank (on black bracket)
Some people mentioned it before in this thread that they connected the compressor directly to battery. If that's safe, i am OK with that... again. I want to have this compressor under the hood and once switch is flipped, compressor start to work, once switch is flipped again to off position compressor shuts off... I am looking I guess for a very simple architecture... So what do I do next and how do I connect it.
1. Do I use the three way splitter ?
2. Do I need to use the pressure sensor ?
3. do I need the relay ?
4. do I need the fuse ?
Thanks in advance...
