To say these axles are big is an understatement. They are freaking HUGE and make the stock D44's look fragile by comparison.
It's been pretty quiet here. Dynatrac informed us the axles are a couple weeks behind schedule, so I'm going to try getting a head start on anything I can do without the axles. I plan on ordering an ARB dual compressor, upgraded stainless braided locker air lines and a PSC cylinder assist. In speaking with PSC, they recommended a Big Bore XDII, pump and reservoir all set up with -AN fittings. -6AN on the pressure side and -8AN return lines and a 8"x1.75 cylinder. This is the first cylinder assist I have run, so any thoughts on that configuration is welcome.
Negative on the -an lines, but Russell Performance sells the kit. It's the same one Eddie installed. There are also race shops that can make Teflon lined stainless hoses to length in case you want to avoid adding additional sections.
I'm biased because I have them too, but machined finish Chambers are my absolute favorite wheels. Did you coat yours with anything to protect them? I use Sharkhide and they're a breeze to clean. Brake dust pretty much rinses right off.
Okay. I know the lines for the Arb. I thought you were talking about doing the whole psc set up with an fittings
I really hated this silver until I started doing raw aluminum components. My wife wants to do bronze inside for the cage.
