Beadlocks?
Blackhawkip
Yes most likely at full lock you're going to get some rubbing up front and out back the rear sway bar links will likely be an issue with that high of backspacing rubbing against the tire no matter which way you install them.
Thanks, that's what I figured. Going to see how much/little spacer I can get away with when I mount them.
Journeyman
At 3" of lift the minimum I could do was 3.5 backspacing. You could definitely drive around but at full stuff and lock with a 4 1/4" I was hitting in the front sway bar and the frame on the backside.
