notnalc68
That dude from Mississippi
I found a Rubicon RockTrac transfer case (Part #52123503ab or aa), with 5500 miles on it to install in my Sport. This write up may be amateurish, compared to something Eddie would do, but I hope it helps someone.
Note: 2012 up automatic transmissions have a different transfer case than manual transmissions, and prior year models.
First things, first. I am not a mechanic or mechanically inclined, but i did this in my driveway, with hand tools. I did it alone, but I recommend you enlist a buddy!
Tools needed:
1/4" drive ratchet
8mm socket
3/8" drive ratchet
16mm socket
18mm socket
14mm flex head gear wrench (a 9/16" will work also)
14mm flex head stubby gear wrench (not required but sure helpful)
16mm flex head stubby gear wrench (yeah, you are probably going to want a stubby for this part)
14mm half moon wrench (or 9/16")
18mm combination wrench
Flat head screwdriver
Floor jack, and I also used a bottle jack.
Some 2x4" wood blocks
Wheel chocks
I also used some 1/2" drive sockets, but you can get by without them.
1) Put the wheel chocks behind your wheels to keep the Jeep from rolling, and set your park brake.
2) Remove the transmission skid plate, using an 18mm socket to remove the 3 bolts. The first 4 photos are from Project-JK (Eddie, I borrowed your photo here, because I have the EVO ProTek Skid System).
3) Remove the transfer case skid plate, using your 18mm socket to remove the 4 bolts holding it. (photos courtesy of www.project-jk.com)
4) Remove the bolts holding the transmission to the mounts on the crossmember, using a 16mm stubby flex head gear wrench.
5) I placed a bottle jack & wood block under the motor (not the pan on the bottom of the transmission), and a floor jack under the transfer case, to support the engine for the next step.
6) Using an 18mm combination wrench & an 18mm socket, remove the 4 bolts holding the crossmember in place and remove the crossmember. The gas tank skid is holding it in place, but it is pretty easy to get out.
7) Using a 16mm socket, remove the 4 bolts in the little plate that attaches the transmission to the crossmember.
8) Using your 8mm, 1/4" drive, decouple the driveshafts.
9) Remove the vent hose, the plug on top of the transfer case, an the shift linkage.
The vent hose just pops off using your fingers...
The shift linkage can be pried off gently, with a flathead screwdriver...
The plug has a little catch on one side, that needs to be pressed in with a screwdriver
10) Using the 14mm wrenches (or 9/16"), remove the six bolts holding the transfer case. Some of them will be pretty hard to get off in the confined space, but it can be done. You can try letting you jacks down a little, to get more room between the Jeep and the transfer case. The ones on the driver's side where the shift linkage bracket is, are the most difficult.
Tools needed:
1/4" drive ratchet
8mm socket
3/8" drive ratchet
16mm socket
18mm socket
Wheel chocks
