Yes, same tubes and C'S but a 44 is worth building up more than a 30
They don't, you're missing the point...How am I giving bad advice by saying sleeves help!!? Yes they help! Please tell me how in the world I'm giving bad advice? I'm reccomend sleeves that cost under 200$ and install in less than 2 hours, that's a lot more reasonable for most people, opposed to reccomending them to save up for a 5k axle
A sleeved housing will still bend, and it will still snapEspecially with a hammer in sleeve - these are just a gimmick that really do nothing. It's the outside diameter that is the main source of strength for any tube. That is why a 3.0x.25 is stronger than a 2.5x.5 tube.
Even if it is a cheap upgrade, it's one of no benefit and better used towards a different housing when the time comes.
I'm going to step up for 35's to 37's on my 2013 JKU Rubicon my questions are. Truss or sleeve the front axle and 4:88 or 5:13 gears.
It's my daily driver. Any input would be helpful
Take a look at the jk stock driveshafts, thin and big, but strong for torque, but will crush on a rock. Now look at a JE reel or Adams shaft, thinner diameter thicker wall.
They do though. Go get 2 straws, see how easy one bends, cut a slit in the second and "sleeve" it. You will feel a small difference. It's crazy to say that adding wall thickness doesn't help strength.. and I disagree about that hammer in sleeves, they actually provide more contact area than weld in ones do, the weld sleeves rely on the rosette weld areas for contact. And yes like you said a thicker diameter tubing is going to be strong than a thinner one with thicker walls. However that diameter only helps in a few different structural ways, not with impact. Take a look at the jk stock driveshafts, thin and big, but strong for torque, but will crush on a rock. Now look at a JE reel or Adams shaft, thinner diameter thicker wall.
With your 2 straw method, I guarantee if you put the end of that straw assembly in your butthole and pulled down on it, it would still bend at your butthole, and I'm not even an engineer.
It DOESN'T MATTER if the sleeve strengthens the tube or not. That's not the point here. Sleeve or not, the tube CAN still bend at the pumpkin just as easy. With your 2 straw method, I guarantee if you put the end of that straw assembly in your butthole and pulled down on it, it would still bend at your butthole, and I'm not even an engineer. And the outer OEM axle tube still can fracture or break with or without a sleeve. It has happened and does happen.
The point most members here are making is that spending the money is un-necessary.
i swear we cant go a week without someone thinking sleeves are D30 miracle makers :naw:
Oh, I was corrected. The OP has a Rubicon. Still the same tubes though. I must have been confused, because there is another thread going, right now, where someone is recommending sleeves in a 30.
As a good friend once told me, it's expensive to be cheap
