J
JKDream
Guest
You say this like its a major concern, and even if it was - a sleeve isn't going to prevent the outside metal from breaking; especially a stupid hammer in sleeve.My original statements were about the tubes splitting after hitting something. Most axles I've seen bent were all at the C.
I guarantee what you saw was bent C's, which is why 90% of the people in the thread recommended gussets.Most axles I've seen bent were all at the C.
Weld-in sleeves are a tight fit, and they are BETTER than hammer in sleeves because they are actually fused to the outside metal. Therefore - if you split/crack/do any type of damage, they will hold the tube TOGETHER. A press fit tube will pull apart and leave you stranded.And no it's nothing like a bolt or trackbar bracket. In regards to tubing it is usually always stronger to have a compression fit opposed to rosette welds. But I guess after years of working on hydraulic cranes and heavy equipment I'll just stick to the advice on here, thanks. And yes welding is stronger than simply bolting something on, I am talking about hammer in sleeves that are a machined fit and support the tubing not only at the welded locations.
This is a moot point anyway because they are both (say it with me) a waste of money.
Then why are you still trying to validate your purchase, and that they will be of any benefit.And yes everyone I understand sleeves will not stop axle failure
Honestly, I highly doubt you were able to make the determination that it wasn't bent, especially from an impact that ripped off four control arm mounts.But I do think that they help, no they will not prevent a bend at the center section. But installing sleeves and gussets for around 230$ it's not a bad idea. I have sleeves and gussets on my rubi 44, had a hard hit on a rock and broke off 4 brackets and bent the rest. The axle itself was still straight as an arrow.
Did you run an alignment bar through it? Doubt it - because you bought a new housing.
You think a "hammer in" sleeve is going to net a compression fit? ...I hope you are joking...
The pure nature of impacting the sleeve repetitively is going to cause bending moments throughout the sleeve and axle housing. And that is without even taking into consideration the human error effect considering you have a moron swinging a hammer on the end... but you're the expert. I guess all the hydraulic press manufactueres around the world have a lot to learn from your years of experience...
I for one, am not well versed in magic. I only focus on things like "facts" so my knowlege is "usually always" lacking here.
