jdofmemi
Dishwasher ended up being a bad pump. Just because I bench-tested it and it worked wasn't conclusive enough. I put the whole thing back together and it started working like it should, but then during the wash cycle, it was cutting out again. I left the bottom cover off so I could get to everything. Just using a piece of wood and lightly tapping the motor, it would free up every single time and start working again. Then would stop until I hit it again. Only out 140 bucks, so not too bad. Not sure when it will get shipped though.
I went through the same thing, bench tested the pump, it worked with no load. Put it together and it pumped about a half a gallon and quit. Drained the washer again and pump worked fine again.
After I did all that I found instructions on how to test the amp draw to tell if the mother was bad.
Cool you found it... same thing happened to my washing machine.. was an easy swap.
That problem seems to be going around. Better than buying a new washer.
Damn things just don't last anymore. Built for maximum energy efficiency, which translates to minimum durability.
Much like our new Jeeps
