VeruGE*144
I got my quiet crawler delivered yesterday also.
I went ahead to install it. Got the factory out pretty quick with some wd40 on the hangers. I had to cut the clamp off at y pipe, Chrysler engineers decided to face the nut up which Is almost impossible to reach with a wrench and there is no way to get enough leverage to get that bitch off.
I put everything in, had to mess around with the tail pipe. I ended cutting of about 3" on the bullet side to make the hangers line up and to stay away from he spring. I also cut about 1.5" off the very end just for esthetics to have the end tip stick out just bearly past the evo facia. I had to pull the tail pipe out like 3 times.
So after all that I went to tighten all the clamps I ended up stripping one and and even then shit was loose around the muffler. I didn't catch that while mocking everything up [emoji19]. The muffler I received did not have to relief cuts to allow the pipe to squeeze a little to be able to clamp on.
I had to pull he entire thing out. I decided to just call it a day, I put the factory garbage can back in. I need to order more clamps now and make the relief cuts on both sides of he muffler.
It should go like butter next time though, so that a plus.
