Haha, it sure does! That's Revcurve on the forum. Unfortunately I haven't met him yet. Looks like we'll have to do a side by side pic when we do!
Seems like it's been forever since I updated Gruff's thread. Finally got him ready for the year mechanically. Got my Exodus 7075 TR mounted up and also a matching Ruffstuff DL.
The install was straighforward but both links cause some unforseen clearance issues in my case. With the TR, the clearance wasn't so much caused by it, rather it was caused by the steering ram mounts from my original install years ago. The positioning of the mount on the axle caused the mount on the TR itself to contact the diff cover. At first we thought it wouldn't be a big deal, and I even consulted Bubba on it. I was going to let it go because the contact was very slight until we had the Jeep up on a lift cycling the steering and axle.
If I would happen to be in a situation that the TR was pushed back by an obstacle and contacted the diff cover hard enough, the steering would get stuck on the ram mount and i'd be screwed. Yes it would flex back after I got off the obstacle, but at that moment I'd be unable to steer at all. Unfortunately I didn't get good pics of this scenario but I ended up having to have new mounts fabbed up for both ends of the cylinder - one on the axle and a mount on the TR.
Clearance issues for the ram with an oversized tie rod are exacerbated by the high steer knuckles. I encountered that when I put on Rancho knuckles. I had to shift the ram mounts to the driver side a couple of inches and also grind down the diff cover a bit to maintain decent steering angle. Glad you got it sorted.
Damn I surprised you had clearance issues to cause you to notch the frame now
Nice work on getting the clearance you needed.
Am I seeing things, or did you have to grind one of the ribs on the Dynatrac cover for the clamp to get the last bit of travel?
The offset on the bracket is an ingenious way to handle the problem. I am gathering ideas for mine in case I go hydro and have the same problems.
This is why I wanted to stay low enough to avoid doing a drag link flip. I didn't want to deal with doing a frame notch to keep up travel.[/url]
Well you'll probably have to do it eventually when you put those PR60's under Fiona.![]()
Lol was about to ask you that question but here they are [emoji106][emoji106][emoji106]
Is your drag link aluminum with the 1 ton GM ends? I need to flip mine now again and now I’m hoping one like that won’t be too big in diameter
Yeah, its a Bubba Bar. Honestly, I think the issue is with the raised mounts on the Reid & Rancho knuckles. You should be fine with the stock ones.
