Thanks! Haha, I'm 5'11" and 187 pounds. I have been lifting for 8 years and have competed in two bodybuilding competitions while in phoenix. I don't have a problem with weight, but the awkwardness of the tire, combined with the height of the mount makes for a challenging lift... I ended up using some 4x4s and my floor jack. And tightening the lugs with spyderlocks and the carrier in the way was a bit of a challenge also.
I tried playing with the johnny joint length as much as possible (about an hour and a half) but the carrier wasn't square to begin with. If you were to lay the carrier down on the four threaded tube sections, only 3 touched the ground. So any further suggestions would be appreciated.
Here's the drivers side lower hole with the other three pinned down...
Well, I'm only 5'-6" and about 170 lbs. I'm getting old, my joints hurt and probably not as in good of shape as I could be but, I can assure you that I can still install a 37" Nitto Trail Grappler mounted on an ATX Slab beadlock wheel in minutes. It's all about technique - not brute strength.
As far as adjustments go, I don't know what to tell you. When we first installed our tire carrier, it was so dead on that it rattled. I purposefully had to misalign it so that it would have a tighter fit and not rattle.
