Does anyone have the nice Grainger one I could borrow? I'd be happy to pay shipping both ways...
GCM 2 said:Check this thread for someone around you, seems a few guys have bought the Marson. Also there are other models listed.
http://www.jk-forum.com/jk-talk-26/best-rivnut-nutsert-tool-money-249040/
btw, here's my JK at the shop getting skinned.![]()
But also, thanks for the heads up! Haha.
Greg, what's the painters tape for? Just to have a surface you can mark on for hole locations?
Also, any ideas on how to seal these to the body? Living in Illinois, rust is an issue, and therefore I dont want an open gap between the corners and the body. Any recommendations?
Doesn't Poison Spyder sell rubber sheet to put between the body and the corners? Will that be sufficient?
The painters tape is for marking the surface and to keep from tearing up the painted surface. As for rust proofing, prior to installing rivnuts, clean, primer and touch up with paint all the raw metal hole edges. You could always apply a nice wide bead of silicone at or near the edges of the new metal skin.
GCM 2 said:That's the vacuum assist canister, unfortunately you are going to need the relocate kit for that. EVO makes one and a couple of other mfg's
Prime8 said:Shit. So that's my only option? Gonna have to strap the stock one back on then...
MTG said:Yes it has to be moved. You also know you have to cut the bottom bar off your stock bumper right?
Prime8 said:Yes. That's already gone. Otherwise I wouldnt have gotten the bumper on far enough to hit the canister! Haha. I thought I had been doing my due diligence by having Chris email me the install directions ahead of time so I could have all my ducks in a row for a smooth install. But the canister isn't mentioned in the directions...
Notajerryskid said:Something else not in the instructions is how to deal with all the panties that will be thrown at you with this on the front of your jeep.![]()
MTG said:I see that now. Here's something else I don't think is in the instructions...I think you are installing the stinger too so put the bumper on so it's resting on the horns. Take 4 of the bolts and run them from the inside out though the spacer plates and your bumper horns (i.e. they are now installed backwards). Then take the stinger and hang it on these bolts. Then use the remaining bolts to push these bolts back out from the front (don't forget the washers). This leaves the second set of bolts installed the correct direction and ready to install the nuts.
Hopefully that makes sense. Trust me it is so much easier than trying to gets the bolts in from the front. Or using tape to secure the spacer plates.
Good luck!
