J
JKDream
Guest
Do you have a few pictures you can post if you have the time with the setup on your stock axles? I'm not sure if you had the bolt on coilover system at that time, but the closer to my setup the better.
I called Evo and it sounds like they do not make a full weld on replacement high mount track bar mount. They recommended welding up to the stock track bar bracket, then reinforcing everything. Which I can do, but it's going to look like Frankenstein by the time it's done.
As far as tie rod ends are concerned, I have a solid 1.5" 7075 tie rod and drag link with 7/8" 3/4 ton TRE's from Ruff Stuff. I know they can bend, but can they take the force of hydro assist?
I know it wasn't directed at me but why don't you just go with something like Synergys weld on bracket or comparable?
They're all good for hydro as mentioned previously.
The stock bracket isn't up to the task, and bracing it is just a poor solution to something fairly easy.
If you're welding already, you might as well improve the entire setup versus improving poop steel.
