sipafz
Update on my heating problem. I had kinda forgot about it until the other day. It was 75 outside and I was sitting at idle for about ten minutes with ac OFF. I just happened to look down and noticed the gauge was at 3/4. Turning the heat on brought it back down as usual.
So today it was a similar temperature outside and gauge was normal. I'd already been sitting at idle for about ten minutes. I decided to turn the AC ON (last year this duplicated the symptom almost immediately). I sat there at idle for ten more minutes and it never acted up. WTF?!
So yet again I'm stumped. In about a month when the heater isn't really necessary, I'm going to bypass the leaking heater core and bleed the system and see what happens after a few weeks. If the issue is fixed, I'll run some kind of heater bypass valve that I can turn on and off (I really don't want to pull the dash and fix the core). But if the problem persists with the core bypassed, then I'll gamble and replace the radiator.
Pulling the dash is not fun on any vehicle. I don’t blame you for wanting to just bypass. I hope that works for you!
