cozdude
Guy with a Red 2-Door
What are these 3 studs for? The ones sticking out of the aluminum foil... Something missing?
Nope they are just there to help hold on the heat shield stuff to the firewall
I just flipped through this whole thread. Nice looking jeep! :thumb:
Dubaibentzen, quick question for you! I love the way the fenders cane out! I noticed in the polar bear thread that you used a jigsaw to cut them did you go the same route this time around?
Any particular reason you went without the stinger on the 1/4 pounder? Just curious.. Considering doing the same thing for my build.
Looking good, man!
Yes same technique: mostly jigsaw. Then a dremel in the tight spots and finally a sawzall for the bigger stuff underneath. It's actually pretty easy once you get going. Inner fenders were just pulled with some brute force. The whole operation was over in less than 3 hrs.
Here's a photo of the excess stuff that was either cut or pulled away.
You kept the support brace underneath the front fenders and used a sawzall for that? Sounds pretty simple! Thank you!b
Organization added! Installed Springtail Solutions side rack with Molle panel today. Now I don't have to be worried about the Powertank rolling around. Easy bolt on and very strong. I got the passenger side version. Might be adding the driver side rack later if I need to fix more stuff.
View attachment 208657 View attachment 208658 View attachment 208659
Added some Cowles Edge Trim to the cut fenders.
And put on a KING sticker on each side above the WAYALIFE gear decal.
View attachment 208654 View attachment 208655 View attachment 208656
Painted the inside of the wheel wells black today.
