![ImageUploadedByWAYALIFE1466512565.061966.jpg ImageUploadedByWAYALIFE1466512565.061966.jpg](https://www.wayalife.com/data/attachments/186/186936-8259b7f4f9243c78d1c14e9e0f1af444.jpg)
Took it for a test drive today, to make sure everything was tuned in. Went fine, except for the rear pinch seam. I thought I had cut it enough... Nope!
![ImageUploadedByWAYALIFE1466512683.619866.jpg ImageUploadedByWAYALIFE1466512683.619866.jpg](https://www.wayalife.com/data/attachments/186/186944-d613ba18232e0703d2c09a526bbecab6.jpg)
The enforcer lift kit worked great with the king shocks. I'm still not sure what setting I want for firmness. I've so far had them at the softest setting and I wanted to try it in the desert. I was fine, but maybe I should set them a few clicks firmer, when offroading.
This is the pinch seam issue I ran into today.
![ImageUploadedByWAYALIFE1466512847.515687.jpg ImageUploadedByWAYALIFE1466512847.515687.jpg](https://www.wayalife.com/data/attachments/186/186955-70db19cec426fc438ed2d83e44a982fe.jpg)
I thought this was sufficient space. But I heard a few scraping sounds from that area, and I saw a bit of the paint was missing. Tire was fine, and I stopped soon after. Now off to find a garage that can cut and weld.
Found a place after 2 km. It was cheap and effective. And I literally got to see my car ON FIRE! Not for the weak hearted.
![ImageUploadedByWAYALIFE1466513264.459113.jpg ImageUploadedByWAYALIFE1466513264.459113.jpg](https://www.wayalife.com/data/attachments/186/186980-ae18d77f246f5867fbb5b3bf597d3975.jpg)
The black spray paint plus the foam inside the seam was quite flammable when the guy was cutting. No big deal for the guy and a bit of water helped. Hehe.
Passenger side was cut with an angle grinder.
![ImageUploadedByWAYALIFE1466513423.941101.jpg ImageUploadedByWAYALIFE1466513423.941101.jpg](https://www.wayalife.com/data/attachments/186/186985-b1e152481e53ea29c4848a888678f72d.jpg)
![ImageUploadedByWAYALIFE1466513450.167999.jpg ImageUploadedByWAYALIFE1466513450.167999.jpg](https://www.wayalife.com/data/attachments/186/186992-a517ae43d6e77185cbd8a6eeefa2bd8a.jpg)
![ImageUploadedByWAYALIFE1466513469.897189.jpg ImageUploadedByWAYALIFE1466513469.897189.jpg](https://www.wayalife.com/data/attachments/186/186996-40c4b3ceb5fd1cc09d851be29100f601.jpg)
Then finally a few steel plates were cut to fit the holes and everything welded nicely together plus a bit of black paint.
![ImageUploadedByWAYALIFE1466513551.115605.jpg ImageUploadedByWAYALIFE1466513551.115605.jpg](https://www.wayalife.com/data/attachments/187/187004-2cc9af5ff3cb11dbc4df89e329a8c380.jpg)
That should do it. I guess I'll know if enough was cut next time I'm in the desert.
