I apologize man - I didn't see your post until tonight - hopefully these help? If you are looking for something specific let me know!
Thanks Ddays, those will help out a lot!, i see that you have what appears to be the synergy trackbar bracket. the raised trackbar bracket from dynatrac has slightly less surface area to weld the PSC tabs on but it looks like it will all come together, a bit tight though.
Looks good. I Iike the cut fender look.
Can't wait to see those wheels and tires mounted up.
Those wheels and tires look sick!
How does/did the shark hide product go on? Do you buff it off after putting it on or does it soak into the aluminum? 1 or 2 coats? Going with those wheels eventually is why I asked
Really, it was a very simple application. I wiped the wheels down with lacquer thinner and then wiped the sharkhide on. No buffing. I did use a brush to apply it to the openings in the wheels as it was easier to reach into them that way. I then applied to the rest of the wheel with an old lint free rag. They say diaper but anything with little lint will work just fine.
Edit: it doesn't say anything about more than one coat. It states on the label that one coat will last for a couple years. I'll probably just go with one coat & see how it wears.
It sure looks good, someday I'll get there but I'm too much of a tight ass to buy anything till my tires wear out which is hard to do when it only got 1600 miles on it last year
First up is the new bumper. Full Metal Fabworks Apex Pinnacle and a set of JW Speaker fogs. Too bad Truck-Lite hasn't come out with a fog yet.
First remove Smittybilt SRC bumper the dealership replaced after the wreck.
Relocated vacuum pump with bracket from FMF. Similar to the Teraflex bracket. Not sure I am going to leave this here. Going back and forth on where to mount my compressor. Where this is or under the passenger seat....
Had to cut small ear off of the pump mounting bracket.
All painted up. Used paint from SEM - Trim Black. We'll see how it holds up this winter
New Jdubs
Nice craftsmanship
Finished!
I seriously like this bumper, rethinking the evo now. Where did you get it, straight from FMF?
Yessir - nice guy to deal with too! I liked the Evo bumper but I just wanted something a little different. There's a couple other guys here running this bumper. I know AllAmericanInfidel is but not sure of the others. The trimming required is minor. Glad I got this one.
