wjtstudios
Wouldn’t slightly shorter sway bar links work to fix that?
2015 JKUR AEV JK350
1985 CJ8 Scrambler
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Ok i will do this. Thank you.I went through the upper spring bracket with the bulkhead fitting
Yeah but then I got to go buy new ones lol.Wouldn’t slightly shorter sway bar links work to fix that?
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Well before I even got started seeing if I could relocate the brake lines the driver side snapped off about a half an inch over the flare fitting. Yay.
Even better is the dealerships has a unknown ETA back order on the line if I want to replace it.
So I ran down pick me up a flare tool hopefully can fix it.
Sent from my SM-G986U using WAYALIFE mobile app
My Jeep isn’t home but I know one side I cut about half way between the frame rails and put a coupling and a new small section of line, the other side I cut off before it went from inside of the frame to outside, then ran straight to the little 90s I used
The double flare was easy to do you will be good
Where’s Brick???
Don’t forget Marks a plumber when he says it’s “easy”.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
I took it to my folks house to park it inside so a new washer and dryer could be delivered, and Tina could still park inside. She leaves for work at 0500 and I didn’t want her walking outside alone nor did I want to get up either [emoji23]
You’re such a good husband!
2015 JKUR AEV JK350
1985 CJ8 Scrambler
That is really nice. Do you have a picture from the underside and is it secure in any way or just floating through the hole.My Jeep isn’t home but I know one side I cut about half way between the frame rails and put a coupling and a new small section of line, the other side I cut off before it went from inside of the frame to outside, then ran straight to the little 90s I used
Just never ends. Snapped right off....Yay....Front PR44 diff cover bolt. View attachment 349899
Yeah hoping to see how screwed I am when I get home from work today. I had just put all the tools away yesterday and it was a last minute thought to recheck the bolts to see if any came loose again. All good untill the last bolt snapped. I said F it and just closed up the garage and went inside. I was not in the mood to mess with it.
Stupid ferry bolts. I got lucky and was able to get channel locks on it and spin it right out. Now I need to go pick up some new ones.Welcome to the club. I’ve been ignoring this one for a few weeks now. Looking to see what my
options are this weekend. Pretty sure mine is snapped in the casting though.
I hope yours is a easy as mine but doesn't look like that based on the amount of bolt left.
