GraniteCrystal
Thanks for the explanation! The example is very helpful.LōD Offroad;830638 said:"The Destroyer carrier has a Max capacity of 300LBS total, with tire included. If your tire weighs about 75lbs or 85lbs, then you have 225lbs or 215lbs of accessories that can be added. The trail rack capacity is 60lbs. Add your gas can weight and as long as you stay under 300lbs total, you should be fine.
The weight of gas is approx. 6.2lbs per gallon.
For Example:
38" tire - 100lbs
60lbs cooler in the trail rack (Beer of course)
5 gallon jerry cans - 40lbs each side
Hi-Lift jack behind the tire - 30lbs
= 270lbs Total weight on the carrier
This is under the 300lbs Max capacity and is a typical example of the Destroyer carrier capability."
![20170328_103310[1].jpg 20170328_103310[1].jpg](https://www.wayalife.com/data/attachments/219/219369-6d410b2ca52c296dba5ef75c68d99f09.jpg)
![20170328_103324[1].jpg 20170328_103324[1].jpg](https://www.wayalife.com/data/attachments/219/219378-23bdc448098065cc0e98881bf45bdefa.jpg)
![20170328_103317[1].jpg 20170328_103317[1].jpg](https://www.wayalife.com/data/attachments/219/219383-ac0e283cf7e1d04ca06804d123862576.jpg)
