MericaMade
You guys mind elaborating on how you got to this point and the parts needed to accomplish this? I’d really like to clean up the rear frame section by relocating the hard lines. What was all involved to get the result you guys now have? I just bought a set of pro rock 60’s and my rig is in the current state as mericamade rig. Figured while it’s down might aswell make a few small adjustments.
Two ways.. You can hand bend the existing lines to move to them to the new location or splice and flare a new hardline in. I was able to bend the passenger side and make it work just fine. I broke the driver hardline and already had a temp fix so I needed to add some length to it. On the drive side I cut and added a new hardline near the frame under the rear door. There is a oval hole in the shock perch that you drill out to fit the top of the the steel braided line through. You can also pulled up RockJocks or Currie rear antirocker instructions that cover this relocation but it is little farther back on the perch and you drill a new hole. Then use the U clip to hold it in place. If you want some more photos let me know.
Also, I did get 2 inch longer steel brake lines since I moved the mounting location up and inside the frame. Might not been needed but since one of my rear line was barley hanging on, I just went with new ones.
I copied JKBrick and his is a lot nicer looking.
