Looks about right..
Hey branman, look what i did yesterday..,
Now get your saw out
So is your plug on the bottom now?
I know I know ... I have actually been tapping out some lines and browsing some pics..... soon... very soon .... did you use dremel or sawzall?
I took off my perfectly good working motor for the evo no limits. Now I have no worries about it not working or messing up. Seen a ton of People have issues over and over. Probably going to sell it.
Yeah, I always forgot to press the button after I stopped or it would reconnect if I went to fast. The motor is what's really expensive. You selling your coils soon?
Pretty sure looking at it your sway bar link is bent us because it hit the bracket and not because of the drag link. But it's making contact now because it's bent.
Yes, actually getting the evo bolt on's comes with New 3" bump stops and brake lines too. I believe the coils, bumpstops, and 5100s are going to Panda. He gets first dibs. I will still have brand new in the package 4 evo brakelines if anyone wants them.
Yes, actually getting the evo bolt on's comes with New 3" bump stops and brake lines too. I believe the coils, bumpstops, and 5100s are going to Panda, he was the first to ask when mentioned it at camp that night after riding in a rig with coilovers. He gets first dibs, then rccrawler second. If they are still available after that I'll let you know. I will still have brand new in the package 4 evo brakelines if anyone wants them.
I'll take those brake lines too I'll slide you a lil extra $ for them next weekend :yup:
your motor doesn't look like it's flipped properly, the plug should be facing up and towards the radiator to get clearance. As it is, you have exposed the plug to being damaged
So the only way to do that is is after you cut the crossmember. Cool thanks
cutting will give you more room to work but not necessary to rotate. I removed the bolts that hold the sway bar to the frame - just be sure to hold onto it before removing the last bolt, bungee cords help keep it from dropping.
Once the bolts are off and it's hanging down you can rotate it up 90 degrees, bolt the sway bar back up and then fine tune the rotation. I did trim a piece of the plastic shroud next to the radiator - trim carefully, don't cut into the radiator.
Expedition One makes a skid plate that looks like it'll work with many bumpers - I have one on order so I hope it fits with JCR... it does require cutting the cross member but it'll give you more front clearance
2012 and up there isn't plastic shroud to trim on the radiator.
Yeah, i was just looking and scratching my head. I swear oil have it done right, at least for a 2014 model. My plug is facing down just like the write-up idk... Of someone could confirm that for me it would really help.
