bkac
Looks about right.
So in "looks about right" it's the glass half empty or half full?
Looks about right.
Unless me, strizzy Chris and evo instructions are wrong, it looks ok.
Nice! I didn't get a stinger yet but Overlander said to get the bolts in the top you have to trim the frame end plate. Strizzychris probably has it in his write up too
Does anyone know if the PureJeep light bar that was on Rubicat is a direct bolt-on. Will it work with the EVO shackle mounts? Are there any other options out there that may work? The wife drives the jeep to work almost everyday and isn't really excited about the stinger. Want tot see if there are any other options besides running nothing but the bumper.
Thanks
Thanks
I had a similar problem as you are about to when installing your 1/4 pounder after relocating my vacuum pump if you use the EVO relocation bracket. I used the EVO relocation bracket, and with my e-disco motor flipped in the direction that yours is, the motor would hit the drag link while I was turning right. My solution was to flip the motor in the opposite direction, with the plug on top. The spacers from the EVO relocation bracket now help to hold the motor out of the way of the radiator. I still need to bend the transmission line out of the way, but here is how mine looks now. View attachment 99336
getting to your knob Will be harder
He said.... :cheesy::cheesy: He he :thankyou:
it makes life tough if you can't reach your knob.:yup:
I took off my perfectly good working motor for the evo no limits. Now I have no worries about it not working or messing up. Seen a ton of People have issues over and over. Probably going to sell it.
Just flip it with the plug on bottom
(I feel adding more confusion. and a contradictory view, to an already WAY too long discussion about this plug/flip was the only way to go at this point!)
