Clutch
Did you put one spacer on the top and two on the bottom?
Yes.
Carrier is on and is rock solid. But my tailgate is tough to open and close, also the top part of the tailgate is pulled away fro the body and the bottom portion is pulled in towards the body. Guess I have to get back in there and try to straighten it out. Not really sure how though.
Part 4 in the instructions say to remove the door catch, why is this necessary?
Is it hard to close with or without the tire on, or both.
Mine has a slight inward set on the bottom left.
View attachment 269359 View attachment 269360
Try to loosen the hinges again to see if the re-align. Then try to loosen all the tailgate bolts if just the hinges don't work
Forgive me if this is already posted but did you guys see this 40 inch tire on the EVO MFG Pro Hinged Gate. What do you think?
GRBG TRK
That's what my plan is
Just put mine on yesterday with the factory rubi wheel and a spacer until my 37s are on. Is anyone doing anything with the open hole behind the carrier where the rubber tire stop used to be? I'm going to look for plugs for the driver's side one as well as the 3rd brake light but not sure if the passenger side hole behind the carrier is a concern to be left open
A new development. When hitting speed bumps, I was getting a loud "whump" in the back of the jeep. I checked damned near everything and couldn't find it. Turns out it's the tire carrier. It looks like the hinges settled into the bushings enough to give about 1/8" of up travel. So when hitting a bump, the whole carrier hops up and slams down. I found some bronze washers from mcmaster-carr to take up the slack, and all is good again.
