That's a hell of a body lift kit.
Had an interesting discovery on the driver's side coilover bucket:
Seems the suspension installer decided to torch a hole in the back of the shock tower to clear the steering pump :grayno: Granted, the PSC system (phase II) was added after the suspension work done during phase I But sheeshisappointed:
Needless to say, given the reputation of the shop, I was a bit shocked!
Fortunately David, the owner of DCD Customs would not let the Jeep leave his shop in this condition and set about the task of fixing the issue:
Wow. Unbelievably shoddy work. Thankfully it’s fixed now.
Would love to know exactly how you would have done things better with the body and motor still in place. I've given it a lot of thought and I'm not even sure how I would have made that hole. :idontknow:
I’m not sure because I can’t tell from the photo exactly where this is on the Jeep and what access to the area is available. I also don’t know what tools and fabrication skills a professional would have that I don’t. It just seems half assed to me to cut structure like that to gain clearance, particularly without telling the customer about it. If that’s the only solution at reasonable cost, so be it, but a guy spending probably $10k or more for parts and labor for a project like this might like to be informed and maybe consider a more elegant solution (albeit at additional cost).
BTW, I’m not slamming ORE at all. I didn’t know that’s where this work was done until you said it. I’ve never done anything with ORE and have no opinion one way or the other about the quality of their work.
As far as $10k goes, I'm not sure where you're getting that from. Jim said this was AFTER getting his suspension system installed and because he decided to have a PSC installed. Maybe I'm wrong about all this but I seriously doubt that would have cost $10k.
Jim said the “suspension installer” made the cut. I interpreted this to mean while the suspension was being installed. I know what kit he has, and I think it’s safe to assume the kit and installation labor cost about $10k. Perhaps I misunderstood his post.
That’s every DTD. To be honest, I’m not sure why they don’t build it already clearanced.
Not on Moby but then, we're still running a factory Delphi box. But, I'm sure if it were up to Mel alone, it would be.
Well I must say, coming back from lunch I didn't expect to see this thread take the trajectory it did. It reminds of the expression from my Air Force days of "calling in an airstrike on your own position." -- LOL!
My intent was never to throw ORE under the bus, in fact my avoidance of identifying them was because I have always been and remain a fan of Mel and his crew -- good people!
Eddie's right, as an engineer I can see that the hole is not in a location that significantly compromises structural integrity given how forces react in that area -- although perhaps corrosion after some time may become an issue. True -- I never knew it was there and I enjoyed the awesome performance of the vehicle for many trouble-free trail miles. BUT I would have appreciated being told -- I'm sure I would have been fine with it had the situation been explained to me.
In Phase II, along with the tons, 40's and PSC ram assist, etc., the mechanic who did the installation also cut out the bottom of my airbox to clearance the PSC reservoir inlet/outlet hoses -- without letting me know. That effectively defeated my snorkel -- which could have ended badly on a trail like Fordyce on a high-flow day. When I told Mel about it, he immediately took care of the situation -- replaced the airbox and re-routed the PSC hoses. I don't blame ORE for the actions of an individual. While we would prefer every mechanic give his/her personal warranty on their workmanship, that's not the real world. Shit happens now and again.
My connection to DCD for the Hemi swap was through a friend in the industry and got a great deal with the AMW4x4 conversion package, so not in any way a dis on ORE. I'll certainly be going back to ORE again when it comes time to put an Enforcer suspension on my future JT :rock:
I’ve only installed a few DTD’s and so far they’ve all needed it. Oddly enough they’ve never needed the clearance in the same exact spot so maybe that’s why Andrew leaves it alone. Like you said though, it’s not taking away any integrity from the suspension.
Soooo...you’re getting a Jeep truck, are you?
I’m sure the endorphin rush from the new Hemi will placate me for a little while....[emoji16]
So put a Hemi in the truck too. Two birds with one stone.
My thoughts exactly...
