I have nothing to contribute.
21k posts?! Where the hell have I been
I'm a slut. You need to put out more.
I just got the Evo spec coilover's back from King and need to reset my front bump stops. I originally had extra bump added to keep the tires out of the front fenders and forward most body mount, but did some trimming to fix those problems. When checking bump stop at full flex (one side fully compressed and the other fully extended) I need to add 3/4" to protect the shocks, but that leaves 1-1/4" of shaft showing at full bump (both sides fully compressed). Question is - should I set the bump stops for the higher speed problem of both sides compressing (full bump) and let the shocks limit travel for low speed full flex crawling or live with wasted higher speed up travel and set the bump stops for full flex?
If I were you, I would leave it as is. I think for a majority of Jeepers, you aren't going to notice any more benefit of an inch of up-travel while enjoying your Jeep offroad. Just my opinion.
I picked up some aluminum stock yesterday and plan on going a 4-6" front frame chop to stuff the winch under the grill. I will have my Rubicon disconnect, working motor, manual Evo No-limits sway bar disconnect, aluminum Quarter Pounder and Evo tow points for sale when I am done.
Nice job on that relocation mount. Looks good. Where do you get aluminum for something like that?
I knocked out a few more old and ends. Sold my full doors and tailgate, trimmed my fender flares shorter, had my cage powder coated triple bronze, installed Evo aluminum corners, Maxxima tail lights, incorporated 3rd brake lights / license plate lights, made a relocation plate and moved the winch control box under the hood, added tie down loops to strap the spare in the back, modified my 6 ton bottle jack to accept stabilization accessories, mounted a rear view mirror to the cage and added nutserts to the front grill mounting locations. The plastic ones were a pain to take on and off for test fitting.
